HP OfficeJet Pro X451 and X551 Series - Replace the ink cartridges
The product uses four colors and has a different ink cartridge for each color: yellow (Y), cyan (C), magenta (M), and black (K).
  1. Open the ink cartridge door.
    Figure : Open the front door
  2. Push the old ink cartridge inward to unlock it.
    Figure : Push in the installed cartridge to unlock
  3. Grasp the edge of the old ink cartridge and then pull the cartridge straight out to remove it.
    Figure : Remove the old print cartridge
  4. Remove the new ink cartridge from the packaging.
    Figure : Remove the new print cartridge from the packaging
  5. Do not touch the metal connector of the ink cartridge. Fingerprints on the connector can cause print-quality problems.
  6. Insert the new ink cartridge into the product.
    Figure : Insert the new cartridge
  7. Close the ink cartridge door.
    Figure : Close the front door
  8. Place the old ink cartridge in the box and refer to HP's recycling instructions at http://wwww.hp.com/recycle.
