HP OfficeJet Pro X451 and X551 Series - AirPrint
AirPrint
Direct printing using Apple’s AirPrint is supported for iOS 4.2 and Mac OS X 10.7 or later. Use AirPrint to print directly to the product from an iPad (iOS 4.2), iPhone (3GS or later), or iPod touch (third generation or later) in the following mobile applications:
  • Mail
  • Photos
  • Safari
  • Select third-party applications
To use AirPrint, the product must be connected to a wireless network. For more information about using AirPrint and about which HP products are compatible with AirPrint, go to www.hp.com/go/airprint.
You might need to upgrade the product firmware to use AirPrint. Go to www.hp.com/support/ojpx451 or www.hp.com/support/ojpx551.
When using the AirPrint driver, the options and settings will differ from the full-featured driver provided by HP. This document describes the full-featured HP driver features.
