Document ID: c03505023
Version: 1
HP Notebook PCs - Display Rotate Button, Esc Button, and Jog Dial Functions Cannot Be Disabled
Release date : 25-Sep-2012
Last updated : 25-Sep-2012
DESCRIPTION
The Display Rotate button, Esc button, and Jog Dial functions cannot be disabled.
SCOPE
HP EliteBook 2760p Tablet PC
RESOLUTION
The HP EliteBook 2760p Tablet PC is functioning as intended. The only way to actually disable these features is to uninstall the HP Hotkey Support software.
Hardware platforms affected : HP EliteBook 2760p Tablet PC
Support Communication Cross Reference ID : IA03504972
