    Fix Windows 10 Update Issues
    Are you working from home?
HP PCs - How to Download, Install, and Use HP Support Assistant (Windows)
This document is for HP and Compaq computers with Windows 10, 8, and 7.
HP Support Assistant helps keep your HP computer in working order by finding updates and providing troubleshooting tools. Most HP computers come with HP Support Assistant. Click the app icon in the task bar, or search Windows for 'support assistant' to open the tool.
