    Windows 11 Upgrade Guide
HP EliteBook 8440p/8440W Notebook PC -"Fn" Key May Not Function Properly
Issue
The Fn key may not function.
One can control the display settings using the keyboard shortcuts (Fn + F4; Fn + F9); knowing that using the Fn key with other keyboard shortcuts like Fn + F3, Fn + imp écr works fine.
Scope:
The models in the following list are equipped with Intel High-Definition (HD) Graphics card:
  • HP EliteBook 8440p Notebook PC
  • HP EliteBook 8440w Mobile Workstation
  • HP ProBook 6440b Notebook PC
  • HP ProBook 6450b Notebook PC
  • HP ProBook 6540b Notebook PC
  • HP ProBook 6550b Notebook PC
Solution
To resolve this issue, please install the following SoftPaq in the following order:
