HP Scanjet Professional 3000 Sheet-feed Scanner - Now capable of scanning 34 inch documents
Issue:
As per the specifications of the Scanjet Professional 3000 Sheet-feed Scanner, the scanner now allows scanning of documents up to 34 inches in length. When the scanner was released it was capable of scanning documents with a max length of 14 inches, which did not satisfy the design requirement or the published specifications.
Solution
The current “HP Scanjet Software and Drivers” version 1.0.0.127, or greater, contains the needed fix. It can be found using Support & Drivers at www.hp.com.
