HP W2072a 20-inch LED Backlit LCD Monitor Product Specifications
Product description
The HP W2072a 20-inch LED Backlit Monitor is designed with integrated speakers and simple "plug and play" connectivity with 1600 x 900 resolution, 3,000,000:1 dynamic contrast ratio and a 5 ms On/Off response time processor.
Product features
Feature
Display size (diagonal)
20 inch
Display type
TN w/LED backlight
Aspect ratio
Widescreen (16:9)
Resolution (native)
1600 x 900
Pixel pitch
0.277 mm
Display colors
200 cd/m2
Contrast ratio
  • 600:1:00 static
  • 3000000:1 dynamic
View angle
  • 90° horizontal
  • 50° vertical
Refresh response time
5 ms On/Off
Display scan frequency (horizontal)
Up to 83 KHz
Display scan frequency (vertical)
Up to 76 Hz
Tilt and swivel angle
Tilt: -5 to + 19°
Video input connector
  • 1 VGA
  • 1 DVI-D
  • 1 Audio
User controls
  • Brightness
  • Contrast
  • Positioning
  • Color temperature (6500k, 9300k, 5000k, custom)
  • Individual color control
  • Serial number
  • Display
  • Clock
  • Clock phase
  • Monitor management
  • Factory reset
Physical security
Security lock
Multimedia
1 Watt/Ch
Feature
  • Plug and Play
  • Language selection
  • Anti-glare
Electrical specifications
Feature
Internal power supply
Power consumption
  • Maximum: 26 W
  • Typical: 20 W
  • Sleep mode: 0.5 W
  • Switch Off: 0.5 W
Standby mode
<0.5 W
Physical specifications
Feature
3.546 kg (7.8 lbs)
Minimum dimensions (W x D x H) (with base)
47.7 x 17 x 35.7 cm (18.8 x 6.7 x 14.1 in)
Dimension (W x H x D) (package)
52.9 x 37.3 x 10.8 cm (20.8 x 14.7 x 4.3 in )
Environmental specifications
Feature
Operating temperature range
5° to 35°C
Operating humidity range
20% to 80% RH
Safety certifications
Feature
Certifications and compliances
  • CE
  • FCC
  • C-Tick
  • VCCI
  • BSMI
  • CB
  • TUV-BAUART
  • TUV-S ISO9241-307
  • CSA
  • CCC
  • CEL
  • CSC
  • EPA
  • Korea e-standby
  • CECP
  • SEPA
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
