    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP Deskjet 3510 Printers - Wireless Printer Setup (Windows)
This document is for HP Deskjet 3510, 3511, 3512, Deskjet Ink Advantage 3515, and 3516 e-All-in-One printers on a computer with Windows.
To set up an HP printer on a wireless (Wi-Fi) network, install the print driver and software from the HP website. When prompted during the installation, select Wireless as the connection type.
Step 1: Prepare for installation
Before setting up the printer on your wireless network, gather the required items, and then check the printer and computer connections.
  1. Gather the following items:
    • Network name: The network name is the SSID.
    • Network password (WEP key or WPA security passphrase)
    • A computer connected to your wireless network
    • Internet access (recommended): HP recommends broadband Internet access such as cable or DSL.
    • Your wireless-capable printer: Place your printer close to the computer during the installation.
    • USB cable: The installer prompts you when to connect the USB cable.
  2. Make sure the printer, router, and computer are all turned on, and that the computer is connected to the same wireless network to which you are connecting the printer.
  3. Disconnect any USB or Ethernet cables from the printer.
Step 2: Download and install the driver
To set up the printer on a wireless network, install the print driver, and then temporarily connect the USB cable from the printer to the computer. This allows the printer to gather the necessary wireless information from the computer.
As an alternative method to downloading the software, you can use the installation CD.
  1. Go to 123.hp.com.
  2. Enter your printer model number, and then click Begin.
  3. Click Download, and then click Open, Save, or Run in any windows that display to download the driver to your computer.
  4. Double-click the driver file in the browser downloads bar or in the Downloads folder on the computer to launch the driver installation.
    Figure : Example of the HP driver file in a browser downloads bar
    Example of the HP driver file in the browser downloads bar
    Figure : Example of the HP driver file in a computer Downloads folder
    Example of the HP driver file in the computer Downloads folder
  5. Follow the on-screen instructions to complete the connection setup and driver installation.
  6. Return to the 123.hp.com page in your web browser to complete the printer registration and activation.
Review these frequently asked questions on setting up the wireless network connection.
