HP LaserJet Enterprise flow MFP M525c - Connect the product to a computer by using a USB cable and install the software (Mac)
This product supports a USB 2.0 connection. Use an A-to-B type USB cable. HP recommends using a cable that is no longer than 2 m.
  1. Connect the USB cable to the product and the computer.
    Figure : USB connection
  2. Install the software from the CD.
  3. Click the product icon, and follow the on-screen instructions.
  4. Click the Close button.
  5. Print a page from any program to make sure that the software is correctly installed.
