HP 655 Notebook PC Specifications
Product description
HP 655 Notebook PC is a value-priced laptop which helps professionals get connected. With a durable casing, it provides an affordable, mobile notebook with AMD technology and multimedia tools.
Product features
Feature
AMD A68M
Processor1
  • AMD Dual Core E2-1800 (1.7 GHz, 1MB L2 cache, 2 cores)
  • AMD Dual Core E1-1200 (1.4 GHz, 1MB L2 cache, 2 cores)
Graphics
  • AMD Radeon HD 7310M Graphics (AMD Dual Core E1-1200 APU)
  • AMD Radeon HD 7340M Graphics (AMD Dual Core E2-1800 APU)
Display2
Internal:
  • 15.6-inch diagonal LED-backlit HD anti-glare (1366 x 768) display
External:
  • Up to 32-bit per pixel color depth
VGA:
  • Supports resolutions up to 2014 x 1536 external resolution @ 60 Hz
HDMI:
  • Supports up to 1080p, 1920 x 1080 at 60 Hz and 1920 x 1200 @ 60 Hz DVI mode
Storage3
320/500/640/750GB 5400-rpm SMART SATA II hard drives
Optical drive
DVD+/-RW SuperMulti DL drive
Memory
Standard:
  • DDR3 SDRAM (1600 MHz)4
  • Two SODIMM slots supporting single channel 2048MB and 4096MB SODIMMs
  • Standard memory up to 6144MB
Maximum:
  • Upgradeable to 8192MB with optional 2048/4096MB SODIMMs in slots 1 and 2
Networking and communications
Wireless:
  • Integrated 802.11 b/g/n 1 x 1 wireless LAN module
  • Bluetooth 2.1 or Bluetooth 4.0 + High Speed (HS)5
Communications:
  • Realtek Ethernet (10/100/1000 NIC)
Audio
  • Integrated Altec Lansing Stereo speakers
  • Integrated microphone
  • High Definition (HD) audio support
Integrated VGA webcam
Pointing devices
  • TouchPad with 2-piece pick button with left and right click functions
  • Multi-touch gestures supported
Keyboard button and keys
On/Off button
1: This system requires a separately purchased 64-bit operating system and 64-bit software products to take advantage of the 64-bit processing capabilities of AMD technology. Multi-core processing with AMD technology is designed to improve performance of this system. Given the wide range of software applications available, performance will vary. AMD’s numbering is not a measurement of clock speed.
2: Resolutions are dependent upon monitor capability, and resolution and color depth settings.
3: Up to 19GB is reserved for the system recovery software.
4: Maximum memory speed supported by the system may be 1333 MHz or 1066 MHz.
5: Bluetooth 4.0 is supported in Windows 7 only, Bluetooth 2.1 is supported in Linux.
Electrical specifications
Feature
Stand-alone power requirements
Nominal operating voltage
18.5 V
Average operating power
Integrated graphics: 12.55 W
Maximum operating power
< 65 W
Physical specifications
Feature
Dimensions (H x W x D)
3.58 x 37.6 x 24.7 cm (1.41 x 14.8 x 9.72 in)
2.45 kg (5.39 lb)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6-cell battery, hard drive, 1GB memory, and optical drive. Weight varies by configuration and components.
Software/OS
Feature
Operating System (OS)
Preinstalled:
  • Genuine Windows 7 Starter Edition 32
  • Genuine Windows 7 Professional Edition 64
  • Genuine Windows 7 Home Premium Edition 64
  • Genuine Windows 7 Home Basic Edition 64
  • SUSE Linux Enterprise Desktop 11
  • FreeDOS
Certified:
Environmental specifications
Feature
Temperature
Operating:
  • 0° to 35°C (32° to 95°F) (non-writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating:
  • -20° to 60°C (-4° to 140°F)
Relative humidity
Operating:
  • 10% to 90%, non-condensing
Non-operating:
  • 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating:
  • 40 G, 2 ms, half-sine
Non-operating:
  • 200 G, 2 ms, half-sine
Random vibration
Operating:
  • 0.75 g
Non-operating:
  • 1.50 g
Altitude (unpressurized)
Operating:
  • -15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
  • -15.24 to 12,192 m (-50 to 40,000 ft)
Safety certifications
Feature
Industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC compliance: Yes
  • Energy Star1: Select models
  • EPEAT2: Registered silver in United States
  • ICES: Yes
  • Australia/NZ C-Tick compliance: Yes
  • CCC: Yes
  • Japan VCCI compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE marking compliance: Yes
  • BNCI or BELUS: Yes
  • Saudi Arabian Compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
1: Configurations of the HP 655 Notebook PC that are Energy Star qualified are identified as HP 655 Notebook PC Energy Star on HP websites and on Energy Star website.
2: EPEAT registration varies by country. EPEAT status listed above applies to U.S.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
