1 Back: Returns to the previous screen.
2 Cancel: Stops the current operation, restores default settings.
3 Selection button: Contextual button that changes depending on what is displayed on the screen.
4 Up button: Use this button to navigate menus and select number of copies.
5 Down button: Use this button to navigate menus and select number of copies.
6 OK: Confirms the current selection.
7 Wireless status light and button: Blue light indicates wireless connection. Press the button to view wireless status and menu options. Press and hold down the button until light blinks to start Wi-Fi Protected Setup (WPS) push button mode.
8 ePrint button: Pressing button displays the Web Services Menu where you can view printer's email address and make ePrint settings.
9 On button: Turns the printer on or off.
Figure : Graphic - The control panel of the HP Deskjet 3520 e-All-in-One series
