    Apache Log4j Update
HP V191 18.5-inch LED Backlit LCD Monitor - Overview
Product description
Slim, 18.5-inch diagonal monitor that delivers impressive, productive computing in a whole new way. Enhanced brightness, contrast and clarity with the power of a Mercury-free LED backlit panel screen. The simple, “plug and play” connectivity relieves IT tie-ups with a quick start-up and go solution.
This product is specific to APJ only.
Product features
Feature
Type
TN (Twisted Nematic) LED Backlit LCD
47 cm (18.5 in) widescreen; diagonally measured
Active area (W x H)
40.98 x 23.04 cm (16.13 x 9.07 in.)
Aspect ratio
16:9
Viewing angle (typical)1
Up to 90° horizontal/50° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
200 cd/m2 (nits)
Contrast ratio (typical)1
600:1
Dynamic contrast ratio (typical)1
3,000,000:1
Response rate (typical)1
5 ms (on/off)
Pixel pitch
0.3 mm
Pixels Per Inch (PPI)
84.7
Backlight lamp life (to half brightness)1
30,000 hours
Color gamut (typical)1
68%
Color support2
16.7 million colors
Anti-glare
Yes
Tilt range
-5° to +19°
Swivel range
No
Height adjustable
No
Pivot rotation
No
Base
Attachable, ships detached
Languages
  • German
  • Simplified Chinese
  • Traditional Chinese
  • Japanese
  • English
  • Spanish
  • French
  • Italian
  • Netherlands
  • Portuguese
  1. All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
  2. With the use of FRC technology.
