When the answer mode is set to Automatic, the printer rings-to-answer setting determines the number of times the telephone rings before the printer answers an incoming call.
If the printer is connected to a line that receives both fax and voice calls (a shared line) and that also uses an answering machine, you might need to adjust the rings-to-answer setting. The number of rings-to-answer for the printer must be greater than the rings-to-answer on the answering machine. This allows the answering machine to answer the incoming call and record a message if it is a voice call. When the answering machine answers the call, the printer listens to the call and automatically answers it if it detects fax tones.
The default setting for rings-to-answer is five for the U.S. and Canada, and two for other countries/regions.
Refer to the following table to determine the number of rings-to-answer to use:
Recommended rings-to-answer for the telephone configuration
Type of telephone line
Recommended rings-to-answer setting
Dedicated fax line (receiving only fax calls)
Set to a number of rings within the range shown on the control-panel display.
The minimum and maximum number of rings allowed varies by country/region.
One line with two separate numbers and a ring-pattern service
One or two rings.
If you have an answering machine or computer voicemail for the other telephone number, make sure that the printer is set to a greater number of rings than the answering system. Also, use the distinctive-ring feature to differentiate between voice and fax calls.
Shared line (receiving both fax and voice calls) with only an attached telephone
Five rings or more.
Shared line (receiving both fax and voice calls) with an attached answering machine or computer voicemail
Two rings more than the answering machine or computer voicemail.
To set or change the number of rings-to-answer, use the following steps:
From the Home screen on the printer control panel, touch the Setup button
Touch the Fax Setup menu.
Touch the Basic Setup menu.
Touch the Rings to Answer button.
Use the keypad to enter the number of rings, and then touch the OK button.
