HP 3115m Notebook PC - Removing and Replacing the Wireless Module
This document is provided to assist in removing and replacing the wireless module for the HP 3115m Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
  • Small, smooth-tipped needle nose pliers (optional)
  • Tweezers
  • Small, Phillips-head (P1 and P00) screwdrivers
Parts required
The replacement part number will vary depending on the wireless module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
802.11a/b/g/n 2 x 2 WiFi and Bluetooth 3.0+HS combination adapter (Ralink 3592BC8)
630813-001
Yes
Intel Centrino Advanced-N 6230 half-minicard - 802.11B/G/N (Most of World)
636672-001
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the wireless module, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Wireless module from the menu on the upper left hand side of the screen.
Click here to view the wireless module removal video (right-click on the link to open in a new window/tab).
Wireless module removal
  2.   note:
    • The following video depicts a specific configuration of the notebook. The same removal and replacement procedures apply to all configurations of the notebook.
    • Depending on your notebooks configuration, you may have either a WLAN or WLAN/Bluetooth Combo module. However, the removal and replacement of these modules is identical and demonstrated in the following video.
  3.   caution:
    Use care when disconnecting the wireless antenna cables from the wireless module. Damaged cables or connectors can degrade notebook performance.
    Carefully disconnect the wireless antenna cables from the wireless module by grasping the connectors with a small pair of needle nose pliers or tweezers.
    Make careful note of which wireless antenna cable is connected to each terminal on the wireless module for later replacement.
  4. Remove the 3-mm P1 Phillips-head screw that secures the wireless module to the system board and allow it to release to the spring tension position.
  5. Grasp the wireless module by the edges and pull gently to remove it.
  6. Place the wireless module in a static dissipative bag.
Wireless module replacement
  1. Grasp the wireless module by the edges and remove it from the static dissipative bag.
  2. Align the notch in the wireless module with the key in the wireless module slot on the system board.
  3. At an angle, gently insert the wireless module into its slot on the system board.
  4. Press the wireless module down and replace the 3 mm P1 Phillips-head screw that secures the wireless module to the system board.
  5.   caution:
    Use care when connecting the wireless antenna cables to the wireless module. Damaged cables or connectors can degrade notebook performance.
    Reconnect the wireless antenna cables to the wireless module.
  6. Route the wireless module antenna cables through the routing channel in the base enclosure.
