HP 3115m Notebook PC - Removing and Replacing the Service Door
This document is provided to assist in removing and replacing the service door for the HP 3115m Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the service door that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Service cover in charcoal finish (includes two rubber feet and shielding)
659503-001
Yes
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the service door, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library) then select Service door from the menu on the upper left hand side of the screen.
Click here to view the service door removal video (right-click on the link to open in a new window/tab).
Service door removal
  2.   note:
    The following video depicts a specific configuration of the notebook. The same removal and replacement procedures apply to all configurations of the notebook.
  3. Slide and hold the battery release latch (identified with a battery icon) into the release position.
  4. Slide the service door toward the front of the notebook and remove.
Service door replacement
  1. Align and place the service door into position on the base enclosure.
  2. Slide the service door toward the rear of the notebook until it is properly seated and the battery release latch clicks.
Country: Flag Serbia
