HP Z620 Workstation - Removing and Replacing Serial Port Adapter
This document is provided to assist in removing and replacing the serial port adapter for the HP Z620 Workstation.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Parts required
The replacement part number will vary depending on the serial port adapter that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Secondary serial port PC board (full-height)
392414-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the serial port adapter, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Serial port adapter from the menu on the upper left hand side of the screen.
Serial port adapter removal
This video was developed using a pre-production version of the workstation. The chassis and parts shown might not exactly match the current production version, but the part removal and replacement steps are the same.
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Disconnect the serial port adapter cable from the system board.
  3. Press the two release latches and rotate the PCI retention clamp until it is fully open.
  4. Remove the serial port adapter from the chassis.
    If customer is not replacing the serial port adapter with another option, cover the open slot on the PCI bulkhead with a metal slot cover.
Serial port adapter replacement
  1. If customer is installing a new serial port adapter, remove the slot cover from an unused slot on the PCI bulkhead.
  2. Position the serial port adapter in the slot.
  3. Rotate the PCI retention clamp down over the PCI bulkhead.
  4. Press the two PCI retention clamp tabs on the rear of the chassis until they lock into place.
  5. Connect the serial port adapter cable to the system board.
  6.   note:
    Please refer to the product-specific maintenance and service guide at for any future technical information and/or installation guidelines for this component. Click here to refer the product-specific maintenance and service guide.
Country: Flag Serbia
