Document ID: c03286567
Version: 1
HP Notebook PCs - WinZip Cannot Save Settings Due to Controls Being Off-Screen
Release date : 17-Apr-2012
Last updated : 17-Apr-2012
DESCRIPTION
Due to the small size of the HP Mini 1104 display panel, certain user interface elements are not available for selecting in the WinZip program. In WinZip, under Settings > Select Option the controls for OK, Cancel and Help are pushed off-screen. They are not available through scrolling or window respositioning. As a result, certain settings for WinZip cannot be saved.
SCOPE
HP Mini 1104
RESOLUTION
To resolve this issue, do the following:
  1. Click Start, select Control Panel, then select Appearance and Personalization.
  2. Select Adjust screen resolution.
  3. Under Orientation, select Portrait or Portrait (Flipped).
  4. Click OK then Keep changes when prompted.
  5. Return to Winzip and move the program window until the 3 controls are visible.
  6. Select the desired control option (OK, Cancel or Help).
  7. Repeat steps 1~4 to set the dispay resolution back to Landscape or Landscape (Flipped).
Hardware platforms affected : HP Mini 1104
Support Communication Cross Reference ID : IA03286371
