HP Z420 Workstation - Removing and Replacing the Front Memory Duct
This document is provided to assist in removing and replacing the front memory duct for the HP Z420 Workstation.
Minimum skill level
The end user should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Parts required
The replacement part number will vary depending on the front memory duct that is being replaced. If a part is listed as "Yes" under "Requires Return", then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Front Memory Duct Assembly
663346-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the front memory duct, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Front memory duct from the menu on the upper left hand side of the screen.
Front memory duct removal
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Press the two release tabs on the front memory duct and pull it straight up and out of the chassis.
Front memory duct replacement
  1. Lower the front memory duct into the chassis and press until it snaps into place.
Please refer to the product-specific Maintenance and Service guide for any future technical information and/or installation guidelines for this component. Click here to access product-specific Maintenance and Service guide.
Country: Flag Serbia
