HP Z420 Workstation - Removing and Replacing the Hood Sensor
This document is provided to assist in removing and replacing the hood sensor for the HP Z420 Workstation.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The End user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the hood sensor module that is being replaced. If a part is listed as "Yes" under "Requires Return", then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Hood sensor module
638816-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the hood sensor, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Hood sensor from the menu on the upper left hand side of the screen.
Hood sensor removal
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Disconnect the hood sensor cable from the system board.
  3. Slide the hood sensor out of the slot on the chassis rail and remove it.
Hood sensor replacement
  1. Slide the hood sensor into the slot on the chassis rail.
  2. Connect the hood sensor cable to the system board.
Please refer to the product-specific Maintenance and Service guide for any future technical information and/or installation guidelines for this component. Click here to access product-specific Maintenance and Service guide.
Country: Flag Serbia
