HP Z420 Workstation - Removing and Replacing the 2.5-inch Hard Drive for External Drive Bays
This document is provided to assist in removing and replacing the 2.5-inch hard drive for external drive bays for the HP Z420 Workstation.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the 2.5-inch hard drive for external drive bays that is being replaced. If a part is listed as "Yes" under "Requires Return", then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
160GB SATA, 3-Gb/s, 2.5-inch Solid State Drive (SSD) - With Multi Level Cell (MLC) NAND flash memory
658540-001 (Modified)
Yes
300GB SAS, 6-Gb/s, 10K-rpm, 2.5-inch Hard Disk Dive (HDD)
658535-001 (Modified)
Yes
300GB SATA, 3-Gb/s, 2.5-inch Solid State Drive (SSD) - With Multi Level Cell (MLC) NAND flash memory
658541-001 (Modified)
Yes
2.5 to 3.5-inch Hard Disk Drive (HDD) carrier assembly
675769-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the 2.5-inch hard drive for external drive bays, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select 2.5-inch hard drive for external drive bay from the menu on the upper left hand side of the screen.
2.5-inch hard drive for external drive bays removal
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Disconnect the data and power cables from the drive.
  3. Pull out on the release latch and slide the drive carrier out of the bay.
    In a desktop configuration, push in on the drive lock to release the drive.
  4. Squeeze the two drive rail handles and pull the drive out of the drive carrier.
  5. Flex one side of the drive rail until the aligning pins clear the drive screw holes, and then separate the drive from the drive rail.
2.5-inch hard drive for external drive bays replacement
  1. With the drive rail handles toward the rear of the drive, insert the aligning pins into the screw holes on one side of the drive.
  2. Flex the drive rail and insert the aligning pins into the screw holes on the other side of the drive.
  3. Slide the drive into the drive carrier until it locks in place.
  4. Push the drive carrier into the drive bay until it locks in place.
  5. Connect the power and data cables to the drive.
Please refer to the product-specific Maintenance and Service guide for any future technical information and/or installation guidelines for this component. Click here to access product-specific Maintenance and Service guide.
Country: Flag Serbia
