    Looking for Site Help?
Document ID: c03280706
Version: 1
Advisory: HP Z1 Workstation - Blank Screen After X Server Termination with RHEL 5.7 or RHEL 5.8
Release date : 11-Apr-2012
Last updated : 17-Apr-2012
DESCRIPTION
A blank gray screen occurs after the X server terminates for the first time on HP Z1 in RHEL 5.7 or 5.8. Text mode (run state 3) operates normally.
Configuration:
HP Z1 using Intel HD (integrated) graphics. This issue is not noted when using NVIDIA MXM graphics cards.
RHEL 5.7 or RHEL 5.8 operating system installed (32- or 64-bit).
System startup looks normal, including temporary X server that runs to show the bootup messages. But when that server terminates, the screen goes blank and no user session login server will be visible.
Symptoms:
The screen will go blank (not black, but a light gray indicating the backlight is on) when X server ends No session login screen is presented.
sourceInformation
SCOPE
Information in this document applies to the listed systems configured as follows:
Systems:
  • HP Z1 Workstation
Operating Systems:
  • Red Hat Enterprise Linux 5 (x86)
  • Red Hat Enterprise Linux 5 (x86_64)
RESOLUTION
Disabling RHGB (e.g. by removing "rhgb" from the kernel boot line) allows the server to come up and present the user session login one time, which could be sufficient for many users. After the first logout or other cause of an X server reset, the screen goes blank.
Some users may be able to operate by always rebooting the system when they would normally just log out.
The other way of working with the system is to only use a text mode such as run state 3.
Hardware platforms affected : HP Z1 Workstation
Operating systems affected : Red Hat Enterprise Linux 5 (x86) (deleted) Red Hat Enterprise Linux 5 (x86-64) (deleted)
Support Communication Cross Reference ID : IA03280706
Country: Flag Serbia
