Document ID: c03280705
Version: 1
Advisory: HP Z1 Workstation - Limited Functionality Under RHEL 5.7 or RHEL 5.8
Release date : 11-Apr-2012
Last updated : 17-Apr-2012
DESCRIPTION
Several features of the HP Z1 Workstation, that work properly under other Linux OSes, are inoperative under RHEL 5.7 or RHEL 5.8. These include:
  1. built-in speakers and some other audio functions (although headphones do work);
  2. wireless LAN;
  3. Bluetooth;
  4. USB 3.0;
  5. IEEE 1394a;
  6. media card reader
Configuration:
RHEL 5.7 and RHEL 5.8 operating system installed (32- or 64-bit).
Symptoms:
These features are inoperative. RHEL 5 is not expected to be certified on HP Z1, so no support from Red Hat can be expected.
sourceInformation
SCOPE
Information in this document applies to the listed systems configured as follows:
Systems:
  • HP Z1 Workstation
Operating Systems:
  • Red Hat Enterprise Linux 5 (x86)
  • Red Hat Enterprise Linux 5 (x86_64)
RESOLUTION
No known workaround or solution supported by HP.
Hardware platforms affected : HP Z1 Workstation
Operating systems affected : Red Hat Enterprise Linux 5 (x86) (deleted) Red Hat Enterprise Linux 5 (x86-64) (deleted)
Support Communication Cross Reference ID : IA03280705
