HP LaserJet Pro 300/400 color MFP M375/M475 Series Product - Load paper trays
Load Tray 1
  1. Open Tray 1.
    Figure : Open Tray 1
  2. Pull out the extension tray.
    Figure : Tray 1 extension
  3. If you are loading long sheets of paper, flip out the extension.
    Figure : Flip open the Tray 1 extension
  4. Extend the paper guides fully (callout 1) and then load the paper stack into Tray 1 (callout 2). Adjust the paper guides to the size of the paper.
    Place the paper into Tray 1 with the side to be printed on face-up and the top toward the product.
    Figure : Load Tray 1
Load Tray 2 or optional Tray 3
  1. Pull the tray out of the product.
    Figure : Open Tray 2
  2. Slide open the paper length and width guides.
    Figure : Open the paper guides
  3. To load Legal-size paper, extend the tray by pressing and holding the extension tab while pulling the front of the tray toward you.
    When it is loaded with Legal-size paper, the tray extends from the front of the product approximately 64 mm (2.5 inches).
    Figure : Load Legal-size paper
  4. Place the paper in the tray and make sure that it is flat at all four corners. Slide the side paper width guides so that they align with the paper-size marking in the bottom of the tray. Slide the front paper length guide so that it pushes the stack of paper against the back of the tray.
    Figure : Load paper in Tray 2
  5. Push down on the paper to make sure that the paper stack is below the paper limit tabs on the side of the tray.
    Figure : Make sure the paper is below the tabs on the tray
  6. Slide the tray into the product.
    Figure : Close Tray 2
Load the document feeder
The document feeder holds up to 50 sheets of 75 g/m2 paper.
To prevent damage to the product, do not load an original document that contains correction tape, correction fluid, paper clips, or staples. Also, do not load photographs, small originals, or fragile originals into the document feeder.
  1. Insert the originals into the document feeder face-up.
    Figure : Document feeder
  2. Adjust the guides until they are snug against the paper.
    Figure : Document feeder guides
