    Windows 11 Upgrade Guide
HP t510 Flexible Thin Client Product Specifications
Product description
HP t510 Thin Client features dual core processors and 2GB DDR3 1066-MHz RAM memory capacity, built for a high grade in end-user experiences. It supports Windows based environments with a significant upgrade in virtualized desktop performance with built-in energy efficiency, smart connectivity features and easy set-up guides for PC-like multimedia needs.
Product features
Feature
Processor
VIA Eden X2 U4200 (1 GHz, 2 cores)
VIA VX900
Memory
2GB, 1066-MHz DDR3 RAM (128MB reserved for video)
Flash memory
2 or 4GB
Monitor support
Dual
Connections
Support for parallel, serial, and PS/2 connections
Graphics
VIA ChromotionHD 2.0 integrated
Audio
  • Output: 1/8-inch mini-jack, 24-bit stereo, 192 kHz sample rate
  • Input: 1/8-inch microphone mini-jack, 20-bit stereo, 96 kHz sample rate
Wireless LAN adapter
Atheros 802.11a/b/g/n WIFI adapter
Peripheral support
  • Keyboard: USB or PS/2 (varies by region)
  • Mouse: USB or PS/2 (varies by region)
  • Printer: Local and/or network printers (RDP, ICA, LPD)
  • Video: DVI-I and DVI-D digital video output (plus included DVI-I-to-VGA adapter)
I/O ports and connectors
  • 6 USB 2.0 (two in front, two in rear, two in secure USB compartment)
  • 1 serial
  • 1 parallel
  • 2 PS/2
  • 1 RJ-45
  • 1 DVI-I
  • 1 DVI-D
  • 1 DVI-I to VGA adapter included in carton
Other features
  • Advance performance
  • Software flexibility
  • Convenient connectivity
  • Integrated management
  • HP service and dependability
Technical specifications
Feature
Processor
Standard memory
2GB DDR3 SDRAM
Flash memory
2 or 4GB
Graphics
VIA ChromotionHD 2.0 integrated graphics
10/100/1000 Gigabit
Ports
  • 1 serial
  • 1 parallel
  • 2 PS/2
  • 1 RJ-45
  • 1 DVI-I
  • 1 DVI-D
Electrical specifications
Feature
Power
65 W
Voltage
100 - 240 V ac
Frequency
50 - 60 Hz
Heat dissipation
Idle state:
  • 33.44 BTU/hr at 115 V ac (60 Hz)
  • 33.44 BTU/hr at 230 V ac (50 Hz)
  • 33.23 BTU/hr at 100 V ac (60 Hz)
Off mode:
  • 1.50 BTU/hr at 115 V ac (60 Hz)
  • 1.54 BTU/hr at 230 V ac (50 Hz)
  • 1.54 BTU/hr at 100 V ac (60 Hz)
Physical specifications
Feature
Dimensions (H x W x D)
Without stand:
  • 20.95 x 5.84 x 21.59 cm (8.25 x 2.3 x 8.5 in)
With stand:
  • 21.97 x 5.84 x 21.59 cm (8.65 x 2.3 x 8.5 in)
Without stand:
  • 1.45 kg (3.2 lb)
With stand:
  • 1.49 kg (3.3 lb)
Dimensions and weights are approximate.
Software/OS
Feature
Operating System (OS)
  • HP ThinPro
  • HP Smart Zero Technology Genuine
  • Windows Embedded Standard 2009 Genuine
Supported management software
  • HP Device Manager Agent
  • HP ThinState for rapid deployment
  • HP Easy Tools GUI (available as add-on)
  • HP Smart Zero Client Services
  • Universal Print Driver
  • Adobe PDF Reader (available as add-on)
  • HP Connection Manager
  • Microsoft .NET Framework 2.0 SP2, 3.0 SP2 and 3.5 SP1
  • Microsoft Windows Media Player v12.0
Environmental specifications
Feature
Operating temperature
Standard:
  • 10° to 40°C (50° to 104°F)
Using quick release with a flat panel monitor:
  • 10° to 35°C (50° to 95°F)
Using PCI expansion unit:
Non-operating temperature
-30° to 60°C (22° to 140°F)
Humidity
Condensing:
  • 20% to 80%
Non-condensing:
  • 10% to 90%
Safety certifications
Feature
ECO-Label certifications and declarations
  • Energy Star Category B
  • EPEAT Gold registered1
  • BFR/PVC-free product
Ergonomics
German ZH1/618; EN29241-3, approved
Safety
UL 1950, CSA 950; TÜV-GS (EN60 950) approved
RF interference
FCC Class B; CE Mark; EN55022B; VCCI
1: EPEAT registration varies by country. Click here to see the registration status by country. EPEAT status listed above applies to U.S.
The above web link will take to a non-HP website. HP does not control and is not responsible for the information located outside the HP website.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
