Printer Specifications for HP Deskjet 2510, 2515, 2529 Printers
This document is for HP Deskjet 2510, 2511, 2512, 2514, Deskjet Ink Advantage 2515, 2516, 2520hc, and DeskJet Ultra Ink Advantage 2529 All-in-One printers.
Review this document for detailed technical data, such as model numbers, system requirements, print speeds, connectivity types, physical dimensions, ink cartridges, paper handling, and print specifications.
Figure : HP Deskjet 2510 All-in-One Printer
Image: HP Deskjet 2510 All-in-One Printer
The HP Deskjet Ink Advantage 2510 All-in-One Printer Series has the same physical dimensions as the Deskjet 2510 All-in-One Printer Series, but is black in color.
