HP Scanjet Enterprise 7000 s2 - Detect misfeeds
Detect misfeeds
The misfeed (multipick) detection feature stops the scan process if it senses that multiple pages are fed into the scanner at one time. This feature is enabled by default.
You might want to disable this feature if you are scanning:
  • Multipart forms (a use that HP does not recommend).
  • Documents which have labels or sticky notes attached to them.
To change this setting in an HP Smart Document Scan Software profile, follow these steps:
  1. Open the HP Smart Document Scan Software.
  2. Select a scan profile, and then click Edit profile.
  3. On the Scan Settings tab of the Profile Settings dialog box, click Hardware Options, and then select or clear the Misfeed (multipick) detection check box.
    For detailed information on this feature and its options, see the HP Smart Document Scan Software Help.
Use the ISIS or TWAIN user interface to enable misfeed detection when scanning from non-HP software.
