HP Pro 3340 Microtower PC - Removing and Replacing the Side Cover
This document applies to the HP Pro 3340 Microtower PC.
Before you begin
  • A screwdriver is required for this procedure.
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  • Move the computer to a clear, flat, stable work surface over a non-carpeted floor.
  warning:
Video overview (in English)
To view a video demonstrating the procedure for removing the side cover, right-click the removing the side cover video and select Open link in new window/tab. Additional product videos can be found on the HP Service Media Library.
Videos clips have sound. If the video does not play, get or upgrade the Adobe Flash Player.
Replacement part information
Part Number
Requires Return
Side access panel
657104-001 (Modified)
Yes
Part numbers are subject to change. See the HP PartSurfer Website for current part numbers.
If the part requires return, click on the appropriate link below:
For customers in countries/regions with RoHS legislation* (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the Original Spare part is regulated by RoHS legislation. If your unit contains a part that is labeled with the Modified Spare number, the Modified Spare must be ordered as the replacement part. If your unit contains a part that is labeled with the Original Spare number, please order the Original Spare as the replacement part. In this case either the Original Spare or the Modified Spare may be shipped which will not affect performance or functionality of the unit.
Removing the side cover
Perform the following to remove the side cover:
Remove any CD or DVDs from the optical drive and then detach all cables that connect to the computer.
Review the following safety considerations before performing the following steps. Failure to comply with these safety considerations could result in damage to the product.
Step 1
Loosen the captive thumb screw that secures the panel to the computer.
Loosen the capitve thumb screw.
Step 2
Grasp the handle on the panel and pull towards the rear of the computer.
Release the side panel.
Step 3
Lift the panel off the computer.
Remove the side panel.
Replacing the side cover
Perform the following to replace the side cover:
Step 1
The access panel has several tabs on its top, bottom, and leading edges.
The tabs on the panel fit into slots and over the front lip of the computer.
Align the tabs on the panel over the corresponding slots on the computer.
Replace the side panel.
Step 2
Slide the panel forward to lock it into position.
Slide the side panel forward.
Step 3
Tighten the captured thumb screw to secure the panel to the PC.
Tighten the capturive thumb screw.
Country: Flag Serbia
