Replacing the Hard Drive in HP Omni 27-1000 Series Desktop PCs
This document applies to HP Omni 27-1000 series desktop computers.
Use the steps in this document to help replace a hard drive in your computer. If you want to add a hard drive with more capacity (upgrade), know that you can upgrade to any sized hard drive that meets the connection type in your computer. Most often this is serial ATA (SATA or eSATA). Also know that there are formatting limitations that may be encountered for drives larger than 2 TB. To access all the data on drives larger than 2 TB format the drive using GPT or create multiple partitions smaller than 2 TB.
Before you begin
  • You need a Phillips head screwdriver.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  • Transfer the computer to a clean, flat, stable work surface over a noncarpeted floor. HP recommends that you put down a blanket, towel, or other soft cloth to protect the screen from scratches or other damage.
  • Electrostatic discharge (ESD) can damage your processor, disk drives, expansion boards and other components. HP strongly recommends the use of an antistatic wrist strap and a conductive foam pad when working on the computer.
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
Removing the hard drive
Use these steps to remove the hard drive:
Step 1
To remove the hard drive, first remove the rear cover.
For instructions to remove the rear cover, see the HP support document, Removing and Replacing the Rear Cover.
Removing the rear panel
Step 2
Loosen the captive Phillips screw that holds the hard drive in place.
Loosening the screw
Step 3
Lift the hard drive handle and slide the cage to the side. Then lift it up and remove it from the computer.
Removing the hard drive from the computer
Step 4
Remove the four screws, two on each side of the hard drive cage.
Save the screws for hard drive replacement.
Removing the screws
Step 5
Slide the hard drive out of the cage.
Sliding the hard drive out of the cage
Replacing the hard drive
Use these steps to replace the hard drive:
Step 1
Before installing a hard drive in the cage, make sure there is a rubber grommet in each side hole of the drive cage.
Install a new grommet into any hole missing a grommet.
Grommets
Step 2
To replace the hard drive in the cage, place the cage over the drive...
Aligning the hard drive in the cage
...aligning the screw holes on the side of the drive and the cage.
Step 3
Replace the four screws that fasten the hard drive in the cage.
Replacing the screws
Step 4
Find the six tabs on the underside of the drive cage.
Finding the tabs on the drive cage
Step 5
Find the slots that the tabs fit into inside the computer.
Finding the slots in the computer
Step 6
Align the tabs on the cage near the slots, and then slide the hard drive in until it is secure.
Inserting the drive into the computer
Step 7
Press down on the cage handle.
Pushing down on the handle
Step 8
Tighten the captive screw to secure the hard drive in the computer.
Tightening the screw
Step 9
Replace the rear cover.
MBR or NTFS partitions are limited to 2 TB (without using dynamic disks and volume sets). If you are installing a hard drive that is 2 TB or greater, HP recommends formatting the drive using GPT partitions.
For instructions to replace the rear cover, see the HP support document, Removing and Replacing the Rear Cover.
Replacing the back cover
Country: Flag Serbia
