Adding or Replacing Memory in HP Omni 27-1000 Series Desktop PCs
This document applies to HP Omni 27-1000 series desktop computers.
Before you begin
  • Turn off the computer and disconnect all cables.
  • Transfer the computer to a clean, flat, stable work surface over a noncarpeted floor. HP recommends that you put down a blanket, towel, or other soft cloth to protect the screen from scratches or other damage.
  • Electrostatic discharge (ESD) can damage your processor, disk drives, expansion boards and other components. HP strongly recommends the use of an antistatic wrist strap and a conductive foam pad when working on the computer.
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
Removing the memory
Use the following steps to remove the memory:
Step 1
To remove the memory, first remove the rear cover.
For instructions to remove the rear cover, see the HP support document, Removing and Replacing the Rear Cover.
Removing the rear panel
Step 2
Swing up and remove the EMI shield covering the memory slots.
Pulling up the EMI shield
Step 3
Gently pull out on the retaining levers on each side of the memory module.
Pulling out the retaining levers
Step 4
Make sure the module pops up from the socket.
Making sure the module pops up
Step 5
Pull the memory module free from the computer.
Pulling the memory out of the computer
Replacing the memory
Use the following steps to replace the memory:
Step 1
Find the small notch on the side of the memory module.
Finding the notch on the memory module
Step 2
Find the small tab on the side of the memory socket.
Finding the tab on the memory socket
Step 3
To replace a memory module, angle the module to about 45 degrees and engage the notch on the module with the tab in the socket.
Inserting the memory in the socket
Step 4
Press the memory module down into place until the retaining levers snap into position over the sides of the module.
Pressing down on the memory module
Step 5
Align the bottom edge of the EMI shield over the memory slot cutout on the motherboard shield and press the memory EMI shield into place.
Step 6
Replace the rear cover.
For instructions to replace the rear cover, see the HP support document, Removing and Replacing the Rear Cover.
Pressing down to snap the cover into place
