Document ID: c03125494
Version: 1
HP EliteBook 8560p and 8460p Notebook PC, HP EliteBook 8460w Mobile Workstation, and HP ProBook 6360b, 6460b, 6560b Notebook PC System BIOS Update F.22
Release date : 16-Dec-2011
Last updated : 16-Dec-2011
DETAILS OF CHANGE
  • Updated ME firmware version 7.1.0.1142 to fix an issue where the computer intermittently displays an "ME is in Recovery State..." message.
    This issue ONLY occurs after manually loading Setup Default or Reset BIOS Security to factory default in F10 (BIOS Setup).
  • Added support for a new WWAN module.
  • Fixed an issue where F10 (BIOS Setup) does not show Smart Card Power Options after restarting the computer.
  • Fixed an issue where the computer boots slowly after disabling the modem device in F10 (BIOS Setup).
  • Added support for the SATA 3.0 SSD hard drive.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
HP strongly recommends installing this BIOS version. After installing this BIOS version, BIOS versions earlier than F.20 cannot be installed.
Components affected:
DATE OF CHANGE
Effective date : 09-Jan-2012
Hardware platforms affected : HP EliteBook 8460p Notebook PC, HP EliteBook 8460w Mobile Workstation, HP EliteBook 8560p Notebook PC, HP ProBook 6360b Notebook PC, HP ProBook 6460b Notebook PC, HP ProBook 6560b Notebook PC
