HP Z400/Z800/Z420/Z620 and Z820 Workstations - Power Supply Requirements for the NVIDIA Tesla C2050 and C2075 Computer
The NVIDIA Tesla C2050 and C2075 Computer Processor Cards are only supported on the HP Z800 Workstation if equipped with a 1110-Watt power supply or the HP Z600 Workstation if equipped with a 600-Watt power supply.
Details
The HP Tesla Kit contains a 6 to 8 pin auxiliary power adapter cable. This cable adapter must be connected to the 6-pin PCI auxiliary power cable and to the rear 8-pin power connector of the Tesla card. There is a second power connector on the Tesla card which must not be used. This second power connector is covered by a label.
Connecting both auxiliary power cables of the Z800 power supply to one card is not supported and might damage the card and/or the power supply.
The above-mentioned URL will take you to a non-HP Web site. HP does not control and is not responsible for information outside of the HP Web site.
