    Fix HP Printer issue on macOS
HP LaserJet Enterprise 600 M601, M602, and M603 Series Printer - Install memory
You might want to add more memory to the product if you often print complex graphics, print PostScript (PS) documents, or use many downloaded fonts. Added memory also gives you more flexibility in supporting job-storage features, such as quick copying.
Single inline memory modules (SIMMs) used in previous HP LaserJet products are not compatible with the product.
Install product memory
This product has one DIMM slot.
Static electricity can damage electronic components. When handling DIMMs, either wear an antistatic wrist strap or frequently touch the surface of the DIMM antistatic package, then touch bare metal on the product.
  1. Print a configuration page to find out how much memory is installed in the product before adding more memory.
    1. At the product control panel, press the Home button.
    2. Open the following menus:
      • Administration
      • Reports
      • Configuration/Status Pages
      • Configuration Page
  2. After the configuration page has printed, turn the product off.
    Figure : Power button
  3. Disconnect the power cord and interface cable.
    Figure : Location of the interface cables
  4. Remove the right-side panel by sliding it towards the rear of the product to unlatch it.
    Figure : Right-side panel
  5. Open the access door by pulling on the metal tab.
    Figure : Access door on the formatter cage
  6. Remove the DIMM from the antistatic package.
    To reduce the possibility of damage caused by static electricity, always wear an electrostatic discharge (ESD) wrist strap or touch the surface of the antistatic package before handling DIMMs.
    Figure : Antistatic packaging for the new DIMM
  7. Hold the DIMM by the edges, and align the notches on the DIMM with the DIMM slot. (Check that the locks on each side of the DIMM slot are open.)
    Figure : DIMM alignment
  8. Press the DIMM straight into the slot, and press firmly. Make sure the locks on each side of the DIMM snap into place.
    Figure : DIMM installation
  9. Close the access door, and press firmly until it snaps into place.
  10. Reinstall the right-side panel. Align the tabs on the panel with the slots in the product, and push the panel toward the front of the product until it latches into place.
  11. Reconnect the interface cable and the power cord.
    Figure : Interface cables
  12. Turn the product on.
