HP LaserJet Enterprise 600 M601, M602, and M603 Series Printer - Configure trays
The product automatically prompts you to configure a tray for type and size in the following situations:
  • When you load paper into the tray
  • When you specify a particular tray or paper type for a print job through the printer driver or a software program and the tray is not configured to match the print-job’s settings
The prompt does not appear if you are printing from Tray 1, and it is configured for the Any Size paper size and the Any Type paper type settings. In this situation, if the print job does not specify a tray, the product prints from Tray 1, even if the paper size and type settings in the print job do not match the paper loaded in Tray 1.
Configure a tray when loading paper
  1. Load paper in the tray. Close the tray if you are using a tray other than Tray 1.
  2. The tray configuration message appears.
  3. Press the OK button to accept the detected size. Or, press the back arrow to choose a different configuration, and continue with the following steps.
  4. To modify the tray configuration, press the down arrow to highlight the correct size, and then press the OK button.
    The product automatically detects most paper sizes in trays other than Tray 1.
  5. Press the down arrow to highlight the correct type, and then press the OK button.
Configure a tray to match print job settings
  1. In the software program, specify the source tray, the paper size, and the paper type.
  2. Send the job to the product.
    If the tray needs to be configured, a prompt appears on the control-panel display.
  3. If the displayed size is not correct, press the back arrow . Press the down arrow to highlight the correct size, or highlight the Custom option.
    To specify a custom size, first press the down arrow to highlight the correct unit of measure. Then set the X and Y dimensions by using the numeric keypad or by pressing the up arrow or the down arrow .
  4. If the displayed paper type is not correct, press the back arrow , and then press the down arrow to highlight the paper type.
Configure a tray from the control panel
You can also configure the trays for type and size without a prompt from the product.
  1. Press the Home button.
  2. Open the Trays menu.
  3. Press the down arrow to highlight the size or type setting for the desired tray, and then press the OK button.
  4. Press the up arrow or the down arrow to highlight the size or type. If you select a custom size, select the unit of measure, and then set the X dimension and the Y dimension.
  5. Press the OK button to save your selection.
Country: Flag Serbia
