HP ZR2740w 27-inch LED Backlit IPS Monitor - Specifications
Physical specifications
Specification
Dimensions (H x W x D)
Unpacked with stand:
  • 44 to 54 x 64.6 x 23.5 cm (17.3 to 21.26 x 25.4 x 9.3 in)
Unpacked without stand (head only):
  • 39.2 x 64.6 x 6.8 cm (15.4 x 25.4 x 2.7 in)
Packaged:
  • 75.5 x 35.5 x 48.0 cm (29.7 x 14 x 18.9 in)
Base area (footprint):
  • 33.4 x 23.5 cm (13.1 x 9.3 in)
Head only:
  • 8 kg (17.6 lb)
Unpacked:
  • 10.5 kg (23.1 lb)
Packaged:
  • 13.5 kg (29.5 lb)
Tilt range
-5° to +30°
Swivel range
Yes (+/- 45°)
Height adjustable
Yes (10 cm)
Pivot rotation
Yes
Panel specifications
Feature
Type
In-Plane Switching (IPS) LED Backlit LCD
68.5 cm (27 in) widescreen; diagonally measured
Screen opening (H x W)
59.8 x 33.6 cm (23.5 x 13.3 in)
Optimal resolution
2560 x 1440 @ 60 Hz; 3.7 MP
Aspect ratio
16:9 widescreen
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
380 nits (cd/m²)
Contrast ratio (typical)1
1000:1
Response time (typical)1
12 ms (gray to gray); 14 ms (On/Off)
Pixel pitch
0.2331 mm
Backlight lamp life (to half brightness)
39,000 hours minimum
Color gamut (typical)
72%
Color support2
Up to 1.07 billion colors
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
2: Display of up to 1.07 billion colors on ZR2740w requires use of display port input with 10-bit content.
On Screen Display (OSD) controls specifications
Specification
Buttons or switches
Source, Minus, Plus, Power On/Off
Languages
Not applicable
User controls
Brightness, Source
Signal interface/performance specifications
Specification
Horizontal frequency
90 kHz
Vertical frequency
60 Hz
Native resolution
Preset VESA graphic modes (non-interlaced)
2560 x 1440 @ 60 Hz
Maximum pixel clock speed
250 MHz
User programmable modes
None
Anti-glare
Yes
Default color temperature
6500 K
Video/other inputs specifications
Specification
Plug and play
Yes
USB 2.0 hub
One upstream, four downstream ports (cable included)
Input connectors
(1) Display port connector; (1) Dual-Link DVI connector, HDCP support on display port and DVI
Video cable
Display port, dual-link DVI-D
Video cable lengths
1.8 m (5.9 ft)
Audio
No
Power specifications
Specification
Input power
100 - 240 V ac, 50 to 60 Hz
Energy star power
57 W
Default power
95 W
Maximum power
120 W
Power saving
< 2 W sleep (standby)
Power cable length
1.9 m (6.2 ft)
Environmental specifications
Specification
Operating temperature
5° to 35°C (41° to 95°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
5% to 95%, 38.7°C maximum wet-bulb
Operating altitude
0 to 5,000 m (0 to 16,404 ft)
Non-operating altitude
0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
BFR/PVC free
Yes, except cables
Arsenic-free glass
Yes
Mercury free
Yes
Country: Flag Serbia
