Replace the Imaging Drum for HP TopShot LaserJet Pro M275
Replace the imaging drum
The imaging drum installed in this product is covered by the product warranty. Replacement imaging drums have a one-year limited warranty from the date of installation. The imaging drum installation date displays on the supplies status page. The HP Premium Protection Warranty applies only to the print cartridges for the product.
Do not remove the imaging drum from its package until you are ready to use it.
  1. Remove the paper from the input tray.
    Figure : Remove the paper from the tray
  2. Raise the camera arm to the fully open position.
    Figure : Raise the camera arm
  3. Remove the capture stage and set it aside.
    Figure : Remove the capture stage
  4. Open the print-cartridge door.
    Figure : Open the print-cartridge door
  5. Pull the input tray straight out to remove it.
    Figure : Remove the dust cover
  6. Pull out on the top right portion of the front cover, and rotate it forward to release the right side. Remove the front cover from the product.
    Figure : Remove the front cover
  7. Lift the two levers that hold the imaging drum.
    Figure : Lift the imaging drum levers
  8. Remove the old imaging drum.
    Figure : Remove the imaging drum
  9. Remove the new imaging drum from the packaging. Place the used imaging drum in the bag and box for recycling.
    Figure : Remove the new imaging drum from the packaging
  10. Remove the protective shielding from the new imaging drum.
    Figure : Remove the packing material
    To prevent damage, do not expose the imaging drum to light. Cover it with a piece of paper.
    Do not touch the green roller. Fingerprints on the imaging drum can cause print-quality problems.
  11. Insert the new imaging drum in the product.
    Figure : Install the imaging drum
  12. Lower the two levers that hold the imaging drum.
    Figure : Lower the imaging drum levers
  13. Reinstall the front cover. Insert the left side first, and then rotate the cover into place.
    Figure : Install the front cover
  14. Reinstall the input tray.
    Figure : Install the tray
  15. Close the print-cartridge door.
    Figure : Close the print-cartridge door
  16. Reinstall the capture stage.
    Figure : Install the capture stage
  17. Lower the camera arm.
    Lower the camera arm to protect the camera lens cover from damage.
    Figure : Lower the camera arm
  18. Load the paper in the input tray.
    Figure : Load Tray 1
  19. Adjust the guides until they are snug against the paper.
    Figure : Adjust the guides
