HP ProBook 6465b Notebook PC - Removing and Replacing the Memory Module
This document is provided to assist in removing and replacing the memory module for the HP ProBook 6465b Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the memory module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
8GB, 1333-MHz, PC3-10600 memory module
634091-001 (Original)
Yes
4GB, 1333-MHz, PC3-10600 memory module
621569-001 (Modified)
Yes
2GB, 1333-MHz, 240-pin, PC3-10600 DDR3-1333 SDRAM (SODIMM)
581096-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the memory module, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select Memory module from the menu on the upper left hand side of the screen.
Click here to view the memory module removal video (right-click on the link to open in a new window/tab).
Memory module removal
    Observe all precautions when removing and replacing components.
    The following video depicts a specific configuration of the notebook. The same removal and replacement procedures apply to all configurations of the notebook.
  2. Remove the bottom cover.
    The primary and expansion memory slots are both located under the accessory cover. The primary memory slot is located on the bottom and the expansion memory slot is located on top. If an expansion memory board is installed, it must be removed before the primary memory board can be removed.
  3. Push both arms outward simultaneously to release the memory module to the spring tension position.
    When handling a memory module, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory. Click here to view the instructions for handling a memory board.
  4. Grasp the memory module by the edges and pull gently to remove it.
  5. Place the memory module in a static dissipative bag.
Memory module replacement
  1. Grasp the memory module by the edges and remove it from the static dissipative bag.
  2. Align the notch in the memory module with the key in the memory module slot on the system board.
  3. At an angle, gently insert the memory module into its slot on the system board.
  4. Press the memory module down to latch the arms.
  5. Replace the bottom cover.
Parts return
