Specification
Dimensions (H x W x D)
Unpacked with stand:
Unpacked without stand (head only):
Packaged:
Base area (footprint):
Head only:
Unpacked:
Packaged:
Tilt range
Yes (-5° to +20°)
Swivel range
No
Height adjustable
No
Pivot rotation
No
Base
Attachable, ships detached
- ${title}
- ${title}
- ${title}
- ${title}
HP LV1561x 15.6-inch LED Backlit LCD Monitor - Specifications
Physical specifications
Panel specifications
Specification
Type
Twisted Nematic (TN) LED Backlit LCD
Viewable image area
(diagonal)
39.5 cm (15.6 in) widescreen; diagonally measured
Screen opening
(H x W)
19.35 x 34.42 cm (7.62 x 13.55 in)
Aspect ratio
16:9
Viewing angle (typical)
> 90° horizontal/ > 50° vertical
Brightness (typical)1
200 nits (cd/m²)
Contrast ratio (typical)1
400:1
Response time (typical)1
12 ms (On/Off)
Pixel pitch
0.2768 mm
Backlight lamp life
(to half brightness)
12,000 hours
Color gamut (typical)
60%
Color support2
Display up to 2.62 million colors
note: |
On Screen Display (OSD) controls specifications
Specification
Buttons or switches
Power (On/Off), 4-button OSD (Menu, Plus, Minus, Auto)
Languages
English, German, French, Spanish, Italian, Dutch, Simplified Chinese, Japanese, Portuguese
User controls
Brightness, Contrast, Image Control, Color, Quick View, Language, Management, Information, Factory Reset, Exit
Signal interface/performance specifications
Specification
Horizontal frequency
24 to 83 kHz
Vertical frequency
57 to 63 Hz
Native resolution
1366 x 768 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
Text mode
720 x 400 @ 60 Hz
Maximum pixel clock speed
72 MHz
User programmable modes
Yes (10)
Anti-glare
Yes
Default color temperature
6500 K
Video/other inputs specifications
Specification
Plug and play
Yes
Input connectors
VGA (analog)
Input impedance
75 ohms (VGA)
Video cable
One 15-pin D-sub (VGA)
Video cable lengths
1.8 m (6.0 ft)
Audio
No
Sync input
LVDS
Power specifications
Specification
Input power
100 - 230 V ac, 50 or 60 Hz
Typical power consumption
10 W
Maximum
12 W
Power saving
< 2 W
Power cable length
1.9 m (6.2 ft)
Environmental specifications
Specification
Operating temperature
5° to 40°C (41° to 104°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
10% to 85%, 38.7°C maximum wet-bulb
Operating altitude
0 to 3,000 m (0 to 9,842 ft)
Non-operating altitude
0 to 5,000 m (0 to 16,404 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free glass
Yes
Mercury free
Yes
Link to product overview information
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
