Replacing Cartridges for HP Photosmart 5510 e-All-in-One Printer Series
This document is for the HP Photosmart 5510 e-All-in-One Printer Series.
This document contains steps for replacing the cartridges.
Cartridges types
Consult the following table to identify the correct cartridges for your area.
Americas and Asia Pacific (excluding China, India, and Japan)
Western Europe
Africa, CIS, Japan, and Middle East
China and India
Ink cartridge
HP 564
HP 364
HP 178
HP 862
Video of replacing the cartridges
The following video demonstrates how to replace a cartridge.
This video shows an HP Photosmart 5510 (B111a) printer, but the steps are the same for your printer.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Step one: Replace the cartridges
Follow these steps to replace the cartridges.
  1. If the printer is off, press the Power button to turn on the printer.
  2. Open the ink cartridge access door. The carriage moves to the access area.
    Opening the ink cartridge access door
  3. Press the tab on the front of the ink cartridge inward to release it, and then pull up on the ink cartridge to remove it from the slot.
    Removing the ink cartridge from the slot
  4. Remove the plastic wrap from a new ink cartridge by pulling the orange tab.
    Make sure that you remove the orange pull-tab and plastic wrap completely before you twist the orange cap in the next step. Otherwise, ink might leak from the ink cartridge. When you remove the plastic wrap, the paper label on the top of the ink cartridge tears slightly, which is necessary to vent the ink cartridge.
    Removing the plastic wrap from a new ink cartridge
  5. Remove the orange cap from the ink cartridge. Twist the cap counter-clockwise until it snaps off.
    Removing the orange cap from the ink cartridge
  6. Slide the ink cartridge into its slot, and then press down on the ink cartridge until it snaps into place.
    Make sure that each ink cartridge is installed in the correct slot. Match the shape of the icon and the color of the ink cartridge with the slot that has the same shaped icon and color.
    Reinserting the ink cartridge
  7. Repeat these steps to insert the other ink cartridges.
  8. Close the ink cartridge access door.
Step two: Align the cartridges
After you load the cartridges and close the cartridge access door, the product automatically prompts you to print an alignment page.
  1. On the product control panel, touch OK. The product prints an alignment page.
  2. Open the lid.
    Figure : Open the lid
    Image: Open the lid
  3. Place the alignment page on the scanner glass with the printed side down, and then position it on the front right corner of the glass.
    Figure : Place the alignment page on the scanner glass
    Image: Place the alignment page on the scanner glass
  4. Close the lid, and then touch OK. The alignment page scans.
    If the product does not automatically print an alignment page, follow these steps:
    1. From the home screen, touch the Right Arrow (), and then touch the Setup icon ().
    2. Touch Tools.
    3. Touch the Down Arrow (), and then touch Align Printer. The product prints an alignment page.
    4. Open the lid.
      Image: Open the lid
    5. Place the alignment page on the scanner glass with the printed side down, and then position it along the front right corner of the glass.
    6. Close the lid, and then touch OK. The alignment page scans.
