HP L200cp Monitor - Product Specifications
The HP L200cp is a 50.8 cm (20 inch) LCD monitor.
Figure : Photo of the HP L200cp LCD monitor
 Image of product
Product numbers
WL705A7 and WL705AV
Features
The HP L200cp LCD monitor has the following features:
  • 1600 x 900 factory-set resolution
  • Supports VGA video input connector
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
Technical specifications
LED feature
Specification
Display size
50.8 cm (20 inch) diagonal and viewable image
Panel active area (width x height): 44.2 cm x 24.9 cm (17.4 inches x 9.8 inches)
Display type
TN panel
Input terminal
1 VGA connector
Speakers
None
Scanning frequency
Horizontal scan range 30-83 KHz
Vertical scan range 50-75 Hz
Viewing angle
Horizontal viewing angle: 170 degrees
Vertical viewing angle: 160 degrees
Recommended resolution (H x V)
1600 x 900 @ 60 Hz (same as max and native)
Contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 30,000:1
Response time
5 ms (on/off)
Pixel pitch
0.277 mm
Power source - AC/DC adapter
Input rating: 100 to 230V~
frequency: 50~60Hz
Power consumption: 45 Watts max power consumption (38 Watts typical power consumption) , 1 Watt energy saving mode
Operating environment
Temperature: 10 degrees C to 35 degrees C (50 degrees F to 95 degrees F)
Humidity: 10% RH through 80% RH (non-condensing)
Storage environment
Temperature: -20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Humidity: 5% RH through 90% RH (non-condensing)
Dimensions
H x W x D (unpacked):
48.4cm x 37.4cm x 18.4cm (19 x 14.7 x 7.2 inches)
Unpacked: 3.5 Kg (7.7 lbs)
Country: Flag Serbia
