HP Compaq 6200 Pro Small Form Factor PC - Removing and Replacing the Hard Drive
This document is provided to assist in removing and replacing the hard drive for the HP Compaq 6200 Pro Small Form Factor PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the hard drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
1TB SATA III 6 Gb/s transfer speed hard drive - 7,200 rpm
636930-001 (Modified)
Yes
750GB SATA 3 Gb/s hard drive - 5,400 rpm - With Native Command Queing (NCQ) and Smart IV technology
632938-001 (Modified)
Yes
500GB SATA III 6 Gb/s transfer speed hard drive - 7,200 rpm - With Native Command Queuing (NCQ) and Smart IV technology
636929-001 (Modified)
Yes
320GB SATA 3 Gb/s hard drive - 7,200 rpm
634824-001 (Modified)
Yes
300GB SATA III 6 Gb/s transfer speed hard drive - 10,000 rpm
639695-001 (Modified)
Yes
300GB SATA 3.0 Gb/s hard drive - 10,000 rpm
648963-001 (Modified)
Yes
250GB SATA 6 Gb/s hard drive - 7,200 rpm - With Native Command Queuing (NCQ) and Smart IV technology
636927-001 (Modified)
Yes
160GB SATA III 6 Gb/s transfer speed hard drive - 10,000 rpm
639694-001 (Modified)
Yes
160GB SATA 3 Gb/s hard drive - 10,000 rpm, 2.5-inch form factor - With 2.5-inch mounting adapter
508312-001 (Modified)
Yes
160GB SATA interface SSD (Solid State Disk) drive - With 3.5-inch bay adapter bracket and screws
646809-001 (Modified)
Yes
80GB SATA interface SSD (Solid State Disk) drive - Intel branded, 2.5-inch form factor
607817-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the hard drive, click on the link below. Or use the product video listing on the HP Services Media Library (Click here to go to HP Service Media Library), then select Hard drive from the menu on the upper left hand side of the screen.
Click here to view the hard drive removal video (right-click on the link to open in a new window/tab).
The chassis and internal components of this computer are similar to the HP Compaq 6000 Pro Small Form Factor (SFF) Business PC and the HP Z210 Small Form Factor (SFF) Workstation. Removal and replacement procedures are the same. The above mentioned video link shows removal and replacement procedures for HP Z210 SFF Workstation.
Hard drive removal
  2. Pull up and hold the access panel release latch.
  3. Rotate the panel up and lift it away from the chassis.
  4. Rotate the drive cage to the up position.
  5. Rotate the power supply to the up position.
  6. Disconnect the data and power cables from the back of the drive.
  7. While pressing on the drive release latch, slide the drive back until it stops.
  8. Lift the drive up and out of the drive bay.
If the replacement drive does not include guide screws, remove and reuse the screws from this drive.
Hard drive replacement
  1. Align guide screws on the drive with the J-slots in the drive bay and push the drive down into the drive bay.
  2. Slide the drive forward until it locks into place.
  3. Connect the power and data cables to the drive.
  4. Rotate the power supply to the down position.
  5. Rotate the drive cage to the down position.
  6. Slide the lip on the front end of the access panel under the lip on the front chassis guide rail.
  7. Lower the back end of the panel until it contacts the chassis.
  8. Press down on the access panel until it locks into place.
