HP PCs - Using HP SoftPaq Download Manager
This document is for HP commercial PCs.
HP SoftPaq Download Manager (SDM) is a utility which provides a quick and easy way to download software and driver updates for HP commercial notebook and desktop PCs.
Step 1: Install HP SoftPaq Download Manager (SDM)
Download the utility from the HP website.
  1. In the Softpaq Exe column, click the most recent file.
  2. Click Open, Save, or Run in any windows that display to download the utility to your computer.
  3. Double-click the HP SDM setup file in the browser downloads bar or in the Downloads folder on the computer to launch the installation.
    Example of the HP SDM setup file in the browser downloads bar
    Example of the HP SDM setup file in a computer Downloads folder
  4. Follow the on-screen instructions to install the utility.
Step 2: Download drivers and software
Generate a list of available software and drivers, and then download updates.
