HP Pro 3300/3305 Microtower PC - Specifications
Physical specifications
Feature
Dimensions (H x W x D)
382.3 x 173.2 x 421.1 mm (15.08 x 6.82 x 16.58 in)
Packaging dimensions (H x W x D)
498 x 262 x 522 mm (19.6 x 10.3 x 20.6 in)
10 kg (22 lb)
Shipping weight
12.5 kg (27.5 lb)
Electrical specifications
Feature
Energy consumption
115 V ac:
  • Normal operation: 52.69 W
  • Sleep (Energy Star low power mode): 1.35 W
  • Off: 0.36 W
230 V ac:
  • Normal operation: 53.36 W
  • Off: 0.36 W
100 V ac:
  • Normal operation: 52.22 W
  • Off: 0.36 W
Heat dissipation1
115 V ac:
  • Normal operation: 180 BTU/hr
  • Sleep: 5 BTU/hr
  • Off: 1 BTU/hr
230 V ac:
  • Normal operation: 182 BTU/hr
  • Sleep: 5 BTU/hr
  • Off: 1 BTU/hr
100 V ac:
  • Normal operation: 179 BTU/hr
  • Sleep: 5 BTU/hr
  • Off: 1 BTU/hr
1: Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
Environmental specifications
Feature
Temperature
Operating:
  • 5° to 35°C (41° to 95°F)
Non-operating:
  • -30° to 65°C (-22° to 149°F)
Relative humidity
Operating:
  • 15% to 90% (non-condensing at ambient)
Non-operating:
Shock
Operating:
  • 40 G, half-sine
Non-operating:
  • 35G, T-Shock, 165 cm/s half sine, 2 - 3 ms
Maximum altitude (unpressurized)
Operating:
  • 3048 m (10,000 ft)
Non-operating:
  • 9144 m (30,000 ft)
Safety certifications
Feature
Eco-label certifications and declarations
IT ECO declaration
HP Pro 3300 and HP Pro 3305 Microtower PCs conform to the examination standards (2003 version) under JEITA's Label System.
