HP LaserJet Enterprise P3015 Printer Series - Unable to Print PDF Files Using LPR Command from Windows XP Computer
Issue
Unable to print PDF files using LPR Command from Windows XP computer. Same time it can print the same PDF file using direct FTP.
Sample of how to print using LPR Command
Solution
In most cases, the printers RAM DISK may have been disabled. Which causes not to print raw PDF files. Re-enable the RAM DISK will allow the device to print PDF file. press the Menu button found on the control panel. Next access the CONFIGURE DEVICE menu by using the up and down arrows to navigate the control panel. Once under the CONFIGURE DEVICE menu select the SYSTEM SETUP menu and then the RAM DISK selection and set it to AUTO .
Menu > CONFIGURE DEVICE > SYSTEM SETUP > RAM DISK > Auto
It’s important to note that there are very few reasons to disable the RAM DISK feature unless trying to provide the device with more memory for extremely complex print jobs. In most cases having the RAM DISK Enabled will allow all print jobs to print.
Enabling RAM DISK using EWS
Country: Flag Serbia
