HP Color LaserJet CP3525 Series Printer - Replace the Secondary Transfer Roller
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Secondary transfer roller removal
Do not touch the spongy roller surface unless you are replacing the roller. Skin oils on the roller can cause image quality problems.
  1. Open the right-door assembly.
  2. Use the blue lever (callout 1) to lower the secondary transfer assembly.
  3. Grasp the roller shaft collars, and lift the transfer roller off of the product.
Secondary transfer roller replacement
  1. Reinstall the transfer roller.
    When you reinstall the transfer roller, make sure that the pins on the shaft collars (callout 1) align with the holes in the mounting assembly.
Parts return
