HP Color LaserJet CP3525 Series Printer - Replace the Toner Collection Unit
To view a video demonstrating the procedure for removing the part click here to access the Services Media Library (www.hp.com/go/sml). Select Printers and Multifunction under the Product category, select HP Color LaserJet Printers under the Product family, and then select the printer model under the product series category.
Toner collection unit replacement
  1. Open the front door. Make sure that the door is completely open.
  2. Grasp the blue label at the top of the toner collection unit and remove it from the product.
  3. Place the attached blue cap over the blue opening at the top of the unit.
  4. Remove the new toner collection unit from its packaging.
  5. Insert the bottom of the new unit into the product first and then push the top of the unit until it clicks into place.
  6. Close the front door.
    If the toner collection unit is not installed correctly, the front door does not close completely.
To recycle the used toner collection unit, follow the instructions included with the new toner collection unit.
Parts return
