    Looking for Site Help?
HP LaserJet Enterprise M4555 MFP Series - Use copy functions
Copy
Use the scanner glass to make as many as 9999 copies of small, lightweight paper (less than 60 g/m2 or 16 lb) or heavy paper (more than 105 g/m2 or 28 lb). This includes paper such as receipts, newspaper clippings, photographs, old documents, worn documents, and books.
Use the document feeder to make as many as 9999 copies of a document that has up to 50 pages (depending on the thickness of the pages).
  1. To copy from the scanner glass, place the original document face-down on the glass. Align the corner of the original with the upper-left corner of the glass.
    Figure : Position of paper on the scanner glass
  2. To copy from the document feeder, place the document into the document feeder with the pages facing up.
    Figure : Position of paper in the document feeder
  3. To make copies by using the default copy options, use the keypad on the control panel to select the number of copies, and touch the Start button.
Cancel a copy job
  1. Press the Stop button on the control panel and then touch the name of the job.
  2. Touch the Cancel Job button, and then touch the OK button.
Reduce or enlarge a copy image
  1. From the Home screen, touch the Copy button.
    Figure : Copy button
  2. Touch the Reduce/Enlarge button.
    Figure : Reduce/Enlarge screen
  3. Select one of the predefined percentages, or touch the Scaling field and type a percentage between 25 and 400. Touch the OK button. You can also select these options:
    • Auto: The product automatically scales the image to fit the paper size in the tray.
    • Auto Include Margins: The product reduces the image slightly to fit the entire scanned image within the printable area on the page.
    To reduce the image, select a scaling percentage that is less than 100. To enlarge the image, select a scaling percentage that is greater than 100.
  4. Touch the Start button.
    Figure : Start button
Collate a copy job
  2. Touch the Collate button or the Staple/Collate button.
    Figure : Staple/Collate button
  3. Touch the Collate on (Sets in page order) option.
    Figure : Staple/Collate options
Country: Flag Serbia
