HP Z210 Small Form Factor Workstation - Specifications
System specifications
Specification
Chassis dimensions (H x W x D)
  • Standard desktop orientation: 100 x 338 x 381 mm (3.95 x 13.3 x 15.0 in)
  • Optional SFF Tower orientation (excluding stand dimension): 338 x 100 x 381 mm (13.3 x 3.95 x 15.0 in)
Weight1
  • System weight: 7.6 kg (16.72 lb)
  • Shipping weight: 8.1 kg (17.86 lb)
  • Max supported weight (desktop orientation): 35 kg (77 lb)
System board form factor
BTX 21.2 x 26.7 mm
Processor socket
Single LGA 1155
CPU bus speed
DMI
Intel PCH C206
Memory expansion slots
4 DDR3 memory slots
Memory type supported
DDR3, UDIMM (Unbuffered), ECC & non-ECC
Memory modes
Non-Interleaved for single channel. Interleaved when both channels are populated.
Memory speed supported
1333 MHz DDR3
Memory protection
ECC available on data, parity on address and command
Maximum memory
16GB
Memory configuration (supported)
1GB, 2GB and 4GB ECC and non-ECC unbuffered DIMMs are supported, but not if mixed.
PCI express connectors
  • 1 PCI Express Gen2 x16 LP slot (x16 electrical/x16 mechanical)
  • 1 PCI Express Gen2 x16 LP slot (x4 electrical/x16 mechanical)
  • 1 PCI Express Gen2 x1 LP slot (x1 electrical/x1 mechanical)
PCI connectors (5.0 V)
1 PCI LP slot
Interfaces supported
Integrated (4) Serial ATA interfaces (2 x 6 Gb/s SATA in blue, 2 x 3 Gb/s SATA in black). One port can optionally be used for eSATA.
Serial attached SCSI
None
Integrated graphics
  • Integrated Intel HD Graphics 2000 (on Intel Core i3/Core i5/Core i7 processors).
  • Integrated Intel HD Graphics P3000 (on Intel Xeon E3-12x5 processors).
  • Unified Memory Architecture (UMA)- A region of system memory is reserved and dedicated to the graphics display. DirectX 10.0 compliant; (OpenGL 3.0 on Intel HD Graphics P3000); 1 VGA & 1 DP graphics ports integrated in motherboard.
  • Integrated graphics can support dual display across DP & VGA outputs.
Network controller
Integrated Gbit LAN MAC by Intel PHY Lewisville 82579LM; Management capabilities WOL, PXE 2.1 and AMT 7
External SATA (eSATA)
1 port eSATA capable with optional eSATA After-Market Option cable kit.
IDE connector
No
Floppy connector
No
Network controller
Serial
1 rear port
2nd serial
Yes- requires optional Serial Port Adapter Kit
Parallel
1 internal header (optional parallel port adapter required)
HD integrated audio
Yes
CD-ROM input (Audio)
No
AUX input (Audio)
No
IEEE 1394 connector(s)
  • Front: No
  • Rear: 2 IEEE 1394a (requires optional PCIe card)
  • Internal: No
USB connector(s)
  • Front: 4 USB 2.0
  • Rear: 6 USB 2.0
  • Internal: 4 USB 2.0
HD integrated audio
Yes
Flash ROM
Yes
CPU fan header
Not applicable - passive CPU heatsink
Chassis fan header
Yes
Front PCI fan header
Yes
Front control panel/Speaker head
Yes
CMOS battery holder - Lithium
Yes
Integrated trusted platform module
Integrated TPM 1.2. The TPM module disabled where restricted by law, i.e. Russia.
Power supply headers
Yes
Power switch, power LED & Hard Drive LED header
Yes
Clear password jumper
Yes
Keyboard/Mouse
USB or PS/2
ENERGY STAR qualified (Config Dependent)
Yes
80 PLUS compliant
Yes, gold
1: Configured with 1 hard drive, 1 optical drive and one NVIDIA Quadro NVS 295 low profile graphics card.
Electrical specifications
Specification
Power supply
240 W, 90% efficiency
Power supply fan
92 x 25 mm variable speed
Operating voltage range
90 to 264 V ac
Rated voltage range
100 to 240 V ac
Rated line frequency
50/60 Hz
Operating line frequency range
47 to 63 Hz
Rated input current
  • 4 A @ 100-127 V
  • 2 A @ 200-240 V
Heat dissipation
  • Typical: 136.3 kg-cal/hr (541 btu/hr)
  • Maximum: 276.6 kg-cal/hr (1098 btu/hr)
FEMP standby power compliant
Yes, with Wake-on-LAN disabled: <2 W in S5-power Off
Power consumption in sleep mode (as defined by ENERGY STAR) - Suspend to RAM (S3)
<4 W
Surge tolerant full ranging power supply (withstands power surges up to 2000 V)
Yes
ErP Lot 6- Tier 1 Compliance @ 230 V (<1 W in S5- Power Off)
Yes
ErP Lot 6- Tier 2 Compliance @ 230 V (<0.5 W in S5- Power Off)
Yes
Environmental specifications
Specification
Temperature
  • Operating: 5° to 35°C (40° to 95°F)
  • Non-operating: -40° to 60°C (-40° to 140°F)
Humidity
  • Operating: 8% to 85% RH, non-condensing
  • Non-operating: 8% to 90% RH, non-condensing
Maximum altitude
  • Operating: 3,000 m (10,000 ft)
  • Non-operating: 9,100 m (30,000 ft)
Dynamic shock
  • Operating: Half-sine: 40 g, 2-3 ms
  • Non-operating:
    • Half-sine: 160 cm/s, 2-3 ms (upto 100 g)
    • Square: 422 cm/s, 20 g
Dynamic vibration1
  • Operating: 0.5 g (rms), 5-300 Hz
  • Non-operating: 2.0 g (rms), 10-500 Hz
Cooling
Above 1524 m (5,000 ft) altitude, maximum operating temperature is de-rated by 1°C (1.8°F) per 305 m (1,000 ft) elevation increase
1: Values represent individual shock events and do not indicate repetitive shock events. Values do not indicate continuous vibration.
Multimedia
Specification
Multimedia and audio devices
  • Integrated Intel/Realtek HD ALC261 Audio
  • HP Thin USB Powered Speakers, BFR-PVC free
Storage
Specification
Optical and removable storage
  • HP 16X DVD-ROM SATA Drive
  • HP 16X DVD+-RW SuperMulti SATA Drive
  • HP 22-in-1 Media Card Reader Kit (Workstations)
  • HP Blu-ray Writer
Networking and communications
Specification
Intel Gigabit CT Desktop NIC
  • Connector: RJ-45
  • Controller: Intel WG82574L Gigabit Ethernet Controller
  • Memory: Integrated Dual 48K configurable transmit receive FIFO Buffers
  • Data Rates Supported: 10/100/1000 Mb/s
  • Compliance: IEEE 802.1P, 802,1Q, 802.2, 802.3, 802.3AB and 802.3u compliant, 802.3x flow control
Network transfer rate
  • 10BASE-T (half-duplex) 10 Mb/s
  • 10BASE-T (full-duplex) 20 Mb/s
  • 100BASE-TX (half-duplex) 100 Mb/s
  • 100BASE-TX (full-duplex) 200 Mb/s
  • 1000BASE-T (full-duplex) 2000 Mb/s
Other hardware
Features
Monitors1
  • HP ZR24w 24-inch S-IPS LCD Monitor
  • HP ZR22w 21.5-inch S-IPS LCD Monitor
  • HP LP3065 30-inch Widescreen LCD Monitor
  • HP LP2475w 24-inch Widescreen LCD Monitor
  • HP LP2275w 22-inch Widescreen LCD Monitor
  • HP DreamColor LP2480zx Professional Display
  • HP LP2065 20-inch LCD Monitor
Input devices
  • HP USB Laser Mouse
  • HP SpaceExplorer 3D USB Controller
  • HP USB 2-Button Optical Scroll Mouse
  • HP USB Standard Keyboard
  • HP PS/2 Optical Scroll Mouse
  • HP PS/2 Standard Keyboard
  • HP USB Optical 3-Button Mouse
  • HP USB Smart Card Keyboard
  • HP 2.4 GHz Wireless Keyboard and Mouse
Miscellaneous
  • HP Power Cord Kit
  • HP Workstation Mouse Pad
  • HP Serial Port Adapter
  • HP Internal USB Port Kit
  • HP ENERGY STAR 5.0 Enabled Configuration
  • HP Parallel Port Adapter Kit
1: Screen size is measured diagonally.
Country: Flag Serbia
