HP ProBook 6560b Notebook PC Product Specifications
Product features
Feature
  • Mobile Intel QM67 Express Chipset (vPro configurations with select processors)
  • Mobile Intel HM65 Express Chipset (non-vPro configurations)
Processors
  • 2nd Generation Intel Core i7 Processors
  • Intel Core i7-2620M Processor (2.70 GHz, 4MB L3 cache, 2 cores/4 threads, 35 W)1
    Up to 3.40 GHz with Intel Turbo Boost Technology
  • 2nd Generation Intel Core i5 Processors
  • Intel Core i5-2540M Processor (2.60 GHz, 3MB L3 cache, 2 cores/4 threads, 35 W)1
    Up to 3.30 GHz with Intel Turbo Boost Technology
  • Intel Core i5-2520M Processor (2.50 GHz, 3MB L3 cache, 2 cores/4 threads, 35 W)1
    Up to 3.20 GHz with Intel Turbo Boost Technology
  • Intel Core i5-2410M Processor (2.30 GHz, 3MB L3 cache, 2 cores/4 threads, 35 W)1,2
    Up to 2.90 GHz with Intel Turbo Boost Technology
  • 2nd Generation Intel Core i3 Processors
  • Intel Core i3-2310M Processor (2.10 GHz, 3MB L3 cache, 2 cores/4 threads, 35 W)1,2,3
Graphics
  • Models with discrete graphics (HP 6460b and HP 6560b only): AMD Radeon HD 6470M with 512MB dedicated DDR3 video memory
    Microsoft DirectX 11 (Shader Model 5.0) and OpenGL 4.0 capable
  • Models with integrated graphics: Intel HD Graphics 3000
    Microsoft DirectX 10.1 (Shader Model 4.1) and OpenGL 3.0 capable4
Memory5
  • Standard:
    • DDR3 PC3-10600 SDRAM (1333 MHz)
    • Two SODIMM slots supporting dual-channel memory
    • 2GB, 4GB, and 8GB SODIMMs
  • Maximum: Upgradeable to 16GB with 8GB SODIMMs in slots 1 and 2
  • Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
  • Internal:
    • 15.6-inch diagonal LED-backlit HD anti-glare (1366 x 768 resolution)
    • 15.6-inch diagonal LED-backlit HD+ WVA anti-glare (1600 x 900 resolution)
  • External:
    • Up to 32-bit per pixel color depth
    • DisplayPort supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
    • VGA port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
    • DVI-D (single link) video signal available through DVI port in optional HP Docking Station (sold separately) supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking6
Communications
  • Integrated Intel 82579LM Gigabit7 Network Connection (vPro configurations)
  • Integrated Intel 82579V Gigabit7 Network Connection (non- vPro configurations)
  • 56 K V.92 modem8
Wireless devices
  • HP hs2340 HSPA+ Mobile Broadband Module
  • HP un2430 EVDO/ HSPA Mobile Broadband Module (not available at product introduction)
  • All 802.11 integrated wireless LAN options
  • Intel Centrino Advanced - N 6205 (2 x 2)
  • Intel Centrino Wireless - N 1000 (1 x 2)
  • Broadcom 43224AGN 802.11a/b/g/n WiFi Adapter
  • Broadcom 4313GN 802.11b/g/n WiFi Adapter
Keyboard
The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and a drain system that funnels fluid through a hole in the bottom of the notebook. This minimizes the risk of damage to sensitive components underneath. The 101/102-key compatible keyboard features a fullpitch key layout with desktop keyboard features, such as the isolated inverted-T cursor control keys, editing keys, both left and right control and alt keys, 12 function keys, and 19.05 x 19.05 mm key pitch (center-to-center spacing). U.S. and International key layouts are available. Other features include hot keys for instant access to power conservation and brightness. The HP ProBook 6560b includes a separate numeric keypad.
Launch buttons and function keys
Separate launch buttons provide easy access to the following features: wireless on/off, HP QuickWeb, and volume mute. The HP ProBook 6560b also features a calculator launch button. Function keys provide control of the following features: standby mode, external display, volume down, volume up, HP Power Assistant, and display brightness.
Pointing device
  • Touchpad with on/off button, two-way scroll, gestures, two pick buttons
  • Optional pointstick with two additional pointstick buttons
Expansion card slots
  • ExpressCard/54 slot: Supports ExpressCard/54
    Or
  • Optional integrated smart card reader (replaces ExpressCard/54 slot): Compatible with ISO 7816 compliant Smart Cards PC/SC interface support
  • Secure digital slot: Supports SD (Secure Digital), MMC (MultiMedia Card)
Internal storage
  • Hard drives10:
    • 250/320/500/750GB 7200 rpm SMART SATA II
    • 320GB 7200 rpm SMART SATA II Self Encrypting Drive
  • HP 3D DriveGuard (Microsoft Windows only): The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
  • Solid state drive: 128/160GB
Audio/Visual
  • SRS Premium Sound
  • Integrated stereo speakers
  • Integrated microphone (dual-microphone array when equipped with optional webcam)
  • Button for volume mute; function keys for volume up and down
  • Stereo headphone/line out
  • Stereo microphone/line in
Optional 720p HD webcam:
  • HD format (widescreen)
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280 x 720 resolution (720 p) and up to 30 fps
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
Power supply
  • Models with discrete graphics or quad-core processor: External 90 W Smart AC adapter
  • Models with integrated graphics and without quad-core processor: External 65 W Smart AC adapter
  • Power cord included is 6 ft (1.8 m)
  • Total length including external AC adapter is 12 ft (3.66 m)
  • HP Fast Charge9
System standby time
Up to 1 week
1: Intel's numbering is not a measurement of higher performance.
2: Not available with vPro.
3: Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
4: Intel HD Graphics for configurations with Celeron processor.
5: Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed. Full availability of 4GB or more of memory requires a Microsoft Windows 64-bit operating system or Linux. With Microsoft Windows 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3GB all memory may not be available due to system resource requirements.
6: Resolutions are dependent upon monitor capability, and resolution and color depth settings.
7: The term '10/100/1000' or 'Gigabit' Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
8: Designed for downloads from 56 K modem compliant sources. Maximum achievable download transmission rates currently do not reach 56 KB/s, and will vary with line conditions. Modem availability is subject to country regulatory approval.
9: HP Fast Charge recharges your battery up to 90% within 90 minutes when the system is off. HP Fast Charge does not apply to the 9-cell primary battery, HP ST09 Extended Life Notebook Battery, or HP BB09 Ultra Extended Life Notebook Battery.
10: These hard drives are customer removable and will withstand multiple insertion/removal cycles. Up to 10GB is reserved for the system recovery software.
Physical specifications
Feature
Dimensions (H x W x D)
  • 1.35 in (at front) x 14.72 in x 9.86 in
  • 34.3 mm (at front) x 374 mm x 250.5 mm
  • Starting at 2.50 kg (5.50 lb) with hard drive, weight saver (no optical drive) and 3-cell battery
  • Starting at 2.62 kg (5.76 lb) with hard drive, optical drive and 3-cell battery
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 3-cell battery and WLAN.
Software overview
Feature
  • Preinstalled:
    • Genuine Microsoft Windows 7 Professional 321
    • Genuine Microsoft Windows 7 Professional 641
    • Genuine Microsoft Windows 7 Home Premium 321
    • Genuine Microsoft Windows 7 Home Premium 641
    • Genuine Microsoft Windows 7 Home Basic 321 (select countries)
    • Genuine Microsoft Windows 7 Starter1 (select countries and configurations)
    • Genuine Microsoft Windows Vista Basic 32
    • SuSE Linux Enterprise Desktop 11
    • FreeDOS
  • Supported:
    • Genuine Microsoft Windows 7 Enterprise 321
    • Genuine Microsoft Windows 7 Enterprise 641
    • Genuine Microsoft Windows 7 Ultimate 321
    • Genuine Microsoft Windows 7 Ultimate 641
    • Genuine Microsoft Windows Vista Enterprise 322
    • Genuine Microsoft Windows Vista Enterprise 642
    • Genuine Microsoft Windows Vista Business 322
    • Genuine Microsoft Windows Vista Business 642
    • Genuine Microsoft Windows XP Professional 32
  • Certified: SuSE Linux Enterprise Desktop 11
1: System may require upgraded and/or separately purchased hardware and/or a DVD drive to install the Microsoft Windows 7 software and take full advantage of Microsoft Windows 7 functionality.
2: Certain Microsoft Windows Vista product features require advanced or additional hardware.
Microsoft Windows Vista Upgrade Advisor can help you determine which features of Windows Vista will run on your computer.
The above web link will take you outside the HP website. HP does not control and is not responsible for the information located outside the HP website.
Environmental specifications
Feature
Temperature
  • Operating1:
    • 0° to 35°C (32° to 95°F) (not writing optical)
    • 5° to 35°C (41° to 95°F) (writing optical)
  • Non-operating: -20° to 60°C (-4° to 140°F)
Relative humidity
  • Operating: 10% to 90%, non-condensing
  • Non-operating: 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Altitude
  • Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
  • Non-operating: -15.24 to 12,192 m (1-50 to 40,000 ft)
1:At temperatures above 30°C (86°F), the Intel Core i3-2310M Processor may not run at maximum clock speed.
Safety certifications
Feature
Planned industry standard certifications
  • UL Yes
  • CSA Yes
  • FCC Compliance Yes
  • ENERGY STAR Select models1
  • EPEAT Gold target2
  • ICES Yes
  • Australia / NZ A-Tick Compliance Yes
  • CCC Yes
  • Japan VCCI Compliance Yes
  • KCC Yes
  • BSMI Yes
  • CE Marking Compliance Yes
1: Configurations of the HP ProBook 6360b, HP ProBook 6460b and HP ProBook 6560b that are ENERGY STAR qualified are identified as HP ProBook 6360b ENERGY STAR, HP ProBook 6460b ENERGY STAR and HP ProBook 6560b ENERGY STAR on HP websites.
2: EPEAT Registered TBD in U.S. EPEAT registration varies by country.
