HP Indigo Digital Press - Dripping in Series 3 Indigo Presses
Issue
When press is printing, different sizes of dripping dots are shown in the impression. Sometimes it is not only a dot, the user can see big amount of dripping along the impression.
Solution
In the series 3 presses, the draining mechanism of the bids catch tray is not so robust. The draining hole is stuck with bids residue producing a big amount of liquid in the catch tray.
When catch tray is totally full of liquid and cannot be drained, this residue is falling down between the walls of the press, going through the ILD support and falling down to the substrate.
Actions to be done:
  1. Check the level of catch tray.
  2. If full of residue, drain with a manual pump.
  3. Dismantle the drain mechanism and clean it.
  4. Clean the catch tray.
