HP Photosmart and Deskjet Ink Advantage Products - Ink Cartridge Label is Torn, Partially Detached, or Missing
Issue
When the orange pull tab on an HP 178, 364, 564, 655, 670, 685, or 862 cartridge is removed, the label on the top of the cartridge is torn or partially removed. In other cases, the label may be partially detached.
Figure : Examples of cartridges with torn or partially removed labels
Image: Examples of cartridges with torn or partially removed labels.
Figure : Example of cartridge with partially detached label
Solution
These label conditions are cosmetic only, and should not cause the cartridge to malfunction. You can use the cartridge as usual.
If the number on the top of the cartridge is missing, look for the corresponding supplies number on the sticker inside the product door.
